Manufacturer: Whirlpool
Model Number: wrx735sdbm
need the tech sheet/ service manual and parts list. Thanks
  • Lighthouse
  • jwhezzy2003
  • Casualcamo
Do you know what the last 2 numbers are on the model number? There are 3 possible tech sheets for this model. If the last 2 numbers are 00 then it will use this tech sheet. It may be close enough for the others models as well. There are 4 different parts manuals but you can look at those on searspartsdirect.com
  • 6 years later...
