I've an Amana dryer the kind you can do nothing from the back side, the problem is no model number serial number tag and the wire diagram is missing the give away is it wont heat up and there are no wires to connect to the thermal fuse, it has a moisture sensor control board 504175 that appears good, getting 240 to the element so I'm guessing the board is ok. This type dryer is you need to remove drum to do anything. What is my L O I thks all.
  • Replies 10
  • AccApp
  • kokomo
  • sh2sh2
  • evaappliance
Did you look on the back of the control panel for the model number? That would be really helpful to us
Can you test the heating element’s resistance?
On any dryer if you are getting 240 to the element and it is not heating any, you have a bad element. Lots of old amana dryers have the same element as speed queens
No wires to connect to thermal fuse?
Yeah, what the heck?
this is the control board Amana Dryer if this would have a model number.
Pemco P/N 2143
RSPC-P/N 504175
Rating 120VAC 60Hz 0.? A
DATE -CODE S/N 7290217............ ( 0247 / 02?7 )
That rpsc (Ripon (Wisconsin) Parts and Service Center) number shows up on sears as nla and I can’t find any information elsewhere. These date back to when Amana was owned by Raytheon along with Speed Queen. Still find rpsc on speed queen parts
Here's a list of model numbers that use Part# 504175 Dryness control board.
As far as a part to use to find a wiring diagram this board isn't a really good choice, (in a washer or dryer without a model number tag the best part to use to try and find a wiring diagram is the timer since that is a much more unique part and the diagram would also have the timer chart that would match your machine).
Amana     LGA80AW (PLGA80AW)     DRYER- GAS
Amana     LEA80AW (PLEA80AW)     DRYER- ELE
Amana     LGA80AL (PLGA80AL)     DRYER- GAS
Amana     LEA80AL (PLEA80AL)     DRYER- ELE
Amana     LEC80AW (PLEC80AW)     DRYER- ELE
Amana     LED65AW (PLED65AW)     DRYER- ELE
Amana     LGD65AW (PLGD65AW)     DRYER- GAS
Pick one of the electric dryers to see if maybe it matches yours.
thks willie and others I'll be all over it.
Does the element have continuity?
Post a pic of the element. I am sure someone here could call out a suitable part number.
