KitchenAid KDTE104DSS1 Dishwasher Circulator Pump
Hello:
My KitchenAid dishwasher was not getting dishes clean.  Took apart and cleaned a good amount of calcium build up out.  Put everything back together, still not working.  I stripped all the insulation off so I could try and determine what was not working.
Can hear it fill with water fin, and pump water out, but circulation pump does not run.
I took apart further, checked pump impeller and it clear and spins freely.
Put everything back together again, still not working...
Any other ways I can test to make sure it's the circulation pump before ordering a new one?
Is it common for the motor to quit on these?
Could it be power not getting to the motor?
Thanks ahead for any help.
Tony
  • Toneloc
  • johntech
Verify voltag to pump when it should be running. You should have  120vac between pin 1 and pin 3 at the motor. If you are receiving voltage and the pump does not spin then bad pump. I change quite a few of these pumps. If there is no power to the pump I would check wiring and test for power again at the control board.
Part number: W11032770
120V AC confirmed after fill cycle complete....so must be a bad motor.  Thank you sir!
