Lg icemaker compartment not enough need sensor values
Hello any help would be much appreciated of model. LFX31925ST/00
complaint was was not making enough ice checked freezer cooling properly set at -4 product temperature right around there. Checked the blower appears to be working when I open refrigerator door and hold switch I can feel good airflow coming from the freezer through the duct. Tested the actual icemaker appears to function and harvest properly. Door appears to seal well no air leak through icemaker door chute. There is not much ice in the dispenser and what is there appears to be wet
removed compartment sensor 7.3 k ohms in cup of ice watsr
3.3 at room temperature approx 70f
the he only thing I can think is that the sensor isn't calling for cold air log enough before it shuts off the blower, but I don't know the resistance values of the sensor.
  • Replies 1
  • john63
  • aaron40
If the Serial Number is 311KR or lower...
You'll need a re-designed Grille Fan Assy
AEB73785615
