Manufacturer: Rheem
Type of Appliance: Furnace
Model Number: 80PJ07EBR01
Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Y
Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Y
I am looking for a PARTS LIST list for this furnace. If there is any tech (error code) info that would be great too.  I’ve never worked on a furnace before. It doesn’t seem that difficult  and I feel very confident in working on it.
Thanks for all your help.
Ms Anm
  • Replies 5
  • MsAnn
  • Son of Samurai
  • AccApp
I couldn't find exactly what you were looking for, but I was able to get the installation instructions and technical specs for this model, which might be useful to you.
As for parts, it looks like Rheem has an online parts catalog here: https://www.rheemparts.com/Catalog/
The error code info should be on a sticker inside the blower access panel, ironically you need to remove the panel to see the error codes which cuts the power which clears the code. Most HVAC techs keep a flat magnet to hold the blower door switch closed so they can diagnose it.
As far as the error code on the panel it is not there. The wiring diagram is. No parts list there either.
I appreciate the help but this does not really help. I need a parts list not the catalog. I cannot find a part that I do not know the number of. That’s why I need a parts list.
the other part of the reply is definately not needed. I needed the parts list most of all. Error code info is not critical.
PARTS LIST IS WHAT I NEED.
If you have one great if not so be it.
Edited by MsAnn
Add
Finally located a parts list. Here you go:
OMG that is incrediable. Thank you so much Son of Samuari. I was not expecting this. You are incredible. I truly appreciate all the hard work!
