Model: WT1101CW Top Load GE Washer drains intermittently - mostly doesn't drain. Pump change did not fix the problem
Hello everyone
Washer won't drain.  If I unplug it for about 7 hours, plug it back, then try again, it will drain.  Then I try another load and it won't drain.
Everything I've researched so far said to check hoses and drain pump for obstructions. I did that; couldn't find any obstructions so I ordered a new drain pump from sears.  Just installed it.  Ran two dry "loads", I could hear, see and feel the pump working.  Started a small real  load (with water). Won't drain, pump is not working.  I've unplugged, waited about 30 minutes. Still won't drain and pump doesn't run.
Model WT1101CW
401PNNA37679
I don't remember when I purchased.  It was sometimes after 2008 - new. There is a date on the old pump 4.12.13/1.  I guess that's a date?
  • Replies 20
  • latrenda
    10
  • AccApp
    5
  • john63
    5
  • MoTeD
Built January 2014.
When the Drain Motor was replaced...did it have a new pump motor wire harness in the kit?
Has it been installed?
26 minutes ago, john63 said:
Built January 2014.
John. It did some with new wires but I didn't use them.  I need to replace the wires?
And this is a GE washer?
Sorry. Typo. It's an LG
Making much more sense now. Yes, when a new wiring harness comes with a part don’t assume it not there for a reason.
Yes.
Thank you John and AccApp.  Tomorrow I will replace the wires and try again
11 minutes ago, john63 said:
Yes.
Sounds good.
Wiring is known to break/fail...internally.
The wire harness will appear to be okay/ undamaged...but is not.
1 hour ago, john63 said:
Sounds good.
Egg-Zachary!
It is also wise to heed the words of John 6:3,
"Then Jesus went up on a mountainside and sat down with his disciples."
I apologize in advance, I could not help myself.
Praise the Lord, Jesus Christ!
In my case...I was born in 1963...which accounts for my username:)
Hello again everyone
Well I put the new wire on the drain pump, but I'm having trouble disconnecting the old wire on the washing machine side.  See photo below.
I tried pulling apart with two hands, doesn't budge
Squeezing the sides doesn't help; pressing that tab in the middle doesn't help. And I turned it around and tried pushing where I saw some lines (like removing a battery cover for a small electronic device).  Didn't work.
Is there a special trick to getting it loose or am I just lacking brute strength?
ocYFmxFyf5SjfoHxxFoGovV0pO2Z_GckkE7Q8bZE
More pics
The end of the new wire - the one I can't connect because I can't disconnect the new wire: ywhUHfRB0HNz5vMDojEFWwRUXAAReXAz9t4kvUoF
Same thing, top view
xSUpJwoPOK77as_uPvxvlLi09PsK6wqeEcmnSTp_
I got it apart. I had to get a heavy flat head screw driver and press down and up.  I've attached the new wire; and now I'm running a test dry load.  Pump is currently working. Will try a wet load once this dry load is done.
It’s more of a finesse thing. You just have to push down on the right place. Worst case scenario: you can’t get them apart. Just cut the connectors out and splice the wires together.
You were right about finesse. I wouldn't have gotten anywhere with brute force.  But finally got them apart.  Does a rinse and spin load right now. Will see how goes
Aaargh!!  It stop working.  Wont spin, won't drain. Flashing OE - just like when I had the old pump and old wires :(
Unplugged. In the morning, I'll try replugging and draining again.
Likely failed (intermittent) Main Board
Part number: EBR6262102
To verify...use a Test Meter to check for 120 volts at blue plug.
Simply insert test leads into pump motor plug...and leave them there.
You can either run a test cycle...and monitor voltage to the drain motor or...
Put the washer in SPIN ONLY several times...to check power to motor.
Thank you!
Could also be the pressure switch hose or the pressure switch itself.
