kenmore s/s
buggerman
Kenmore s/s fridge Model# 10657058790 . I have a broken ice dispensor arm/lever and i woulkd like to replace it however I can't get the cover off of the front of the door. Is there a trick to taking the cover off?
Made by Whirlpool, look at the bottom to see if there are two notches that you can pry the bottom up and out with a small screwdriver?
Ok I'll try that. Thank You!
