Kenmore 665.13963K015 Dishwasher powers off mid-cycle
My Kenmore dishwasher powers off during first cycle or sometimes just after cycle finishes drain and starts next cycle.  When it happens display goes dark.  I can hit Stop/Cancel and it will drain water from tub and shut off.  Then will allow another attempt with same result.  Ran diagnostic program and it returned 4 codes F6E6, F6E4, F8E1 and F3E3 If I'm reading codes correct First one is Low water temp. Second Float switch open  Third Slow drain  Fourth Failed OWI calibration.   Not sure if any of those codes would cause a mid cycle power shut off. It fills and does first wash part way or all the way before it  fails.  Any ideas where to start first.  I have been able to repair all my appliances over the years but these new electronic controlled models are definitely different to diagnose.  Any help would be appreciated.  Thanks Dennis
  • Replies 6
  • Bigd64
    4
  • nolazach
  • 16345Ed
  • LaRayParateur
My first inclination would be to test the heater circuit.
Every time I've come across this it as the control.  You don't always have to replace either.  It was always a burnt out pin on the board and it just needed solder.
     But check continuity on the heater first.
    It's very likely the heater most machines shut down with heater failure now.
Thanks for the suggestions I will tackle it this weekend
Checked heater continuity is fine.  Checked all connections all seem fine.  Symptoms are worse now starts cycle and immediately goes to red light cancel cycle and runs drain cycle.
  • 2 weeks later...
Update: After testing the remaining items I decided to order a new control board.   That did the trick the Dishwasher is now working again much to the delight of my wife.  Thanks for the tips
  • 3 weeks later...
LaRayParateur
Sometimes a bad capacitor on the control board can cause a few weird behaviors.
Also, on some models with a vent fan, a bad fan motor could draw enough power from the board to shut off the appliance mid cycle.
Quite a rare situation but if you encounter it, you might wish to unplug the fan and see if the dishwasher will continue further without it.
