Water / ice dispenser  will not work. Stopped suddenly.
  • Replies 4
  • evaappliance
  • applianceman97
  • darren412
  • Mary Ellen
is it making any noise when you push the button ?
if it does , they are bad about this part breaking. 61005614
Check to make sure dispenser is in lock out mode
one of the obvious things that you may want to check is make sure that the freezer door switch is not stuck in the door is open position.  The door switch if its in the closed position will shut down the ice maker and  dispensing unit. If there is a good bulb in the freezer light socket, Push the door switch in and out to see if the switch is operating. If the switch is  good the freezer light bulb will come off and on.. When you close the freezer door make sure the light bulb goes off .  if it doesn't shut off. That would explain why the dispenser and ice maker are not  functioning.
