Inverter Box whirlpool fridge Wrx988sibm
Roosevelt Stewart
I am working on a whirlpool fridge. Compressor not running and the tech sheet is missing. I replace the inverter box but compressor still not running. I and getting 123 volts AC input and 3.3 volts DC to the inverter. I think I need 4-6 volts which leads me to believe that the Main control board may be bad. Inverter is not attempting to start the compressor. Compressor reads 6.4 volts across all leads. Baffled
Did you mean ohms?
Roosevelt Stewart
Sorry, yes ohms
Spec on inverter:
3-6 VDC
You really need tech sheet so you can enter diagnostics to do some testing.
Edited by 16345Ed
Roosevelt Stewart
Thank you. Then if converter is good, it should attempt to start compressor?
Roosevelt Stewart
I agree. Can’t find it anywhere
Are you a professional tech?
Is a 3.3 dc  volt reading coming from the main control to the inverter good enough to have the inverter run the compressor 16345ed ?   I see that you had found the spec range of 3 to 6 volts DC for the inverter. That reading of 3.3 seems to be on the low end but within the specs ??
Right and you’d think it would be near 6VDC when so far below temp.
Roosevelt, you should consider subscribing to this site. Well worth it, I found the tech sheet in less than a minute. Because I have a membership.
I would also test evaporator thermistor(s)
Roosevelt Stewart
I just subscribed. The condenser fan is running by the way
welcome aboard!
Edited by 16345Ed
17 minutes ago, Roosevelt Stewart said:
I just subscribed.
Pro is the only way to go, bro! Welcome to the team
Edited by AccApp
Better go catch it, you'll need it if the compressor starts running as well.
  • Haha 2
Agreed, start with the tech sheet (SvcTest 5, maybe), but FWIW it's tricky to check the inverter output. Have to assume the inverter's good since you've replaced it, but if you run into this again, couple things to keep in mind:
  • The signal that the inverter is looking for is just frequency. The duty cycle or effective (filtered) DC voltage isn't specified, and may not vary with demand in a way that we'd expect. Frequency at min. speed is ~54 Hz. , at max ~ 150Hz.
  • Even when the inverter is getting a demand for compressor runtime, it'll check to see if the compressor is seized or hard to start, and disable compressor output if the compressor isn't turning over as it expects. In practice, I've found that the inverter will pulse its output on for ~ 1/2 second , and if id doesn't like the current draw it sees , it'll wait (maybe 10-20 sec.) and try again. If you're not watching your meter really close (or using a min/max trigger, etc.) , or if your meter has a slow update rate, you may miss the output pulse from a good inverter trying to start a seized compressor.
Come to think of it, it'd be nice if somebody would come out with a 3-phase inverter-based hard start kit. To the best of my knowledge, it wouldn't violate the laws of physics.
2 hours ago, Roosevelt Stewart said:
I just subscribed.
I think you meant that you subscribed as a free Grasshopper member. If you’d like to subscribe as a professsional tech member, this page has more information: https://appliantology.org/store/product/11-professional-appliantologist/
The fox that bit you died
Roosevelt Stewart
Update, turned out to be the compressor. I was able to obtain a tech sheet from the local parts supplier. Thanks for all your help
Roosevelt Stewart
The compressor turned out to be faulty. This type unit is going to be to hard diagnosis. If you can't trust your meter....
How did you determine it was the compressor?
Roosevelt Stewart
Changed the inverter under warranty, checked thermistor, Control boards, all voltages were in range of tech sheet. By the process of elimination, I took a very expensive chance
