RF23HCEDBWW/AA. Ice maker only drops ice if reset button pressed. When pressed drops a few cubes then beeps a few minutes later and no more cubes unless pressed again.
If it's dropping only a few cubes, something's wrong. Are there cubes left in the ice maker after it cycles? (You can use a light and mirror to inspect it). If it's only making a few cubes at a time, there low water pressure so the ice tray is not filling completely. The beep you hear after you cycle the ice maker manually means the water has finished filling the ice maker.
  • Thanks 1
i dont think there are any left. I tried defrosting w hairdryer, didn't make difference.  water pressur to water dispencer seems fine
maybe it makes 6 or so after it dumps them it stops
There is a bulletin out on this one, see if there is air leaking into the ice room from a gap between the wall and the ice room.
Well if the water pressure is good, check the temperature of the ice room. You'll have to do this quickly. Leave a fridge thermometer in the ice room for several hours. It needs to read below 17 degrees or the ice maker won't cycle. Also use a magnet and locate the read switch on the top cover where the left door closes and apply the magnet to that sweet spot until the internal lights go out. With the left door open and the ice bucket removed, In about 5-10 seconds you should hear the ice room fan come on. If you don't hear anything, shine a flash light in behind the ice maker and see if there's ice and frost build up on the back of the ice maker or fan area. If there is, you have a major problem to correct...
  • 2 weeks later...
It seems fixed. I think from it being unplugged for a bit. If it starts again I'll return to thread.  Thanks
