Manufacturer: Kenmore
Model Number: 79073055410
  • Replies 8
  • Son of Samurai
  • Dr. Phil
  • Lighthouse
I'm not finding anything for that model number, and Repair Clinic doesn't think it's valid. Are you sure that's the correct number?
Hmm... Unfortunately, the number doesn't pull up anything on Frigidaire's tech literature site. Anyone else got anything?
@Son of Samurai- be sure you’re including the “.” In the model number when you run your search.
I've tried it with and without the period. Doesn't pull up anything either way.
I ran into the same thing and as Dr. Phil said Sears automatically pulls up a 795* instead of a 790*
If you use the 790 on APP or Repair Clinic it pulls up ranges. Most likely a 795* would be my guess.
Ah, yes, great point @Lighthouse- Sears is aggressive about auto correcting invalid model numbers. Repairclinic is less so. That’s why I suggest using Repairclin in inthe form.
If a model number does not pull up in Repairclinic, it should be a clue that something’s wrong.
Looks like @Dr. Phil has led us on a snipe hunt! ??‍♂️
Holy shit! Did not Sears autocorrected. Well now I know. :-/
