mongowrench
I have a MAH6700AWW which was made by Samsung for Maytag.  The washer will not drain.  The drain pump was not getting power.  Pulling the control board, I find it potted in goo, and it might be hard to go after the relay.  Furthermore, there is some burnt goo in the power area of the board.
The board is unobtainium.  I have found other boards, like the control board for a MAH8700AWW, which the seller says will fit.  But there is a different size display and the functions are different.  I don't know how to configure the 8700 board to work in my model.
The board I am looking for is a 34001479.  Any ideas on substitutions, etc.?
Thanks.
  • Replies 5
  • mastertech011
  • AccApp
  • mongowrench
  • 16345Ed
If the board is not the same it will not work i have seen people use a similar board from the same family of machines  line a 6700 board in a 8700 machine.some functions stop working, but basic functions work. I would rebuild or get a used one.
  • 2 weeks later...
Did you try Ebay. I searched and found 2 but probably would be as cheap to have it rebuilt if you can absorb the down time.
The rebuilders can’t repair these because they are “potted” in whatever that rubber goo is. No one has found a way to remove it cost effectively without damaging the board.
Good grief, well I would be looking for another machine then.
