Has a ra fault how do u master reset fault it also has er error
  • darren412
  • evaappliance
  • Ruiz
  • LearningTech
got to have a model number
Without a model try reseting the power is all you can do really.
 evaappliance is correct you have to supply the model # so you can be assisted . Your ER error code is a keypad membrane failure.  But as mentioned without a Model # the appliance tech who is trying to suggest the help you may need cannotfully give you that information. Many different models can have different solutions to your ER error that you are getting and can have different common solutions to the specific fix for your model.
