GE GFSS2HCYCSS Condenser and Freezer Fans Running All The Time
I have a GE GFSS2HCYCSS that the condenser and freezer fans run constant! I have unplugged the unit and cleaned the condenser, fan and evaporator drain tube. My temps seem to be good freezer is around 5 degrees fridge is 38 degrees. I have turned the unit off and let it sit for over a hour and the fans continue to run. I can hear the compressor come on like normal. My ice will melt and refreeze into one big clump. Thoughts? Suggestions?
  • Replies 5
  • Rwake2000
    4
  • Jedi Appliance Guy
  • KaveMan
How long has it been doing this?
Did the ice melt and refreeze before you unplugged it?
It has been doing this for a few days now! The ice is fine all day then the next day it is one big chunk. It’s almost like the door is being left open or a bad seal but it’s not! I have checked the seals on all the doors they all look good!
Yes it was doing this before I unplugged it.
On the schematic for this model looks like both condenser and evaporator motors get 12VDC supplied at the same time from J2-3 and J2-8 connectors directly off the main board, so I would suspect the board is faulty...
I put a board in it today and it fixed it! I could see where the board was burned up!
