Click here to take the quiz.
Is there a heater or something to stop the freezer drain from freezing up and overflowing? The evaporator defrost function is working properly.
  • Replies 5
  • herfdog
  • 16345Ed
  • Lighthouse
  • Rhubarb Tau
I don't know of a factory drain heater, but I've used the aluminum drain probe from the Samsung leakage kit DA82-01415A .
This unit also is subject to the P-Trap bulletin W10632338B , which can cause frozen defrost drains from guk glueing the original duckbill shut , calls for replacing the duckbill with P-Trap W10619951
Yes to this...
Someone on here turned me on to aluminum fence ties for drain probes. Easy  to bend, shape and cut to size. Cheap.
Thanks for your help!
I keep a couple of the Samsung drain heaters on the truck.
Part number: AP5579885
I keep a bag of the fence ties in my steamer bag. I have used them on the units that the above doesn't work on.
As stated above this particular unit most likely needs the P-Trap update.
Part number: AP5780744
Also carry this on truck
Part number: AP3119957
