    • 12 April 2025 02:00 PM Until 03:00 PM
      When: Saturday, April 12 @10:00 AM Eastern Time.
HI
The bake element was severed so I replaced it. The oven baked once and now it will not heat. All other elements work so I'm at a loss?
  • Replies 12
  • raven316
    6
  • 16345Ed
  • A & G Enterprises
  • LearningTech
Double check your connectors make sure they didn’t come loose.
Other than that need to test for voltage at element.
Thanks, I should have said that I did check the element connectors. I don't have a voltmeter, I'll try to get one.
We need to determine if control is sending voltage to element.
Will a non contact voltage tester work?
no you need to see the voltage that is reading
Noncontact is poor subsitute. You likely have a bad control. But only a meter will tell
OK, I think it's time to call a pro. I replaced the element for a friend but I don't want to screw it up. thanks
One more thing, this range has an error code function but we have not seen one. Does that tell me anything? Do I have to do something to get one to display or do the just show up?
They usually just throw an error, regardless need to verify any errors by taking voltage readings...
Roger, I was just trying to figure out why we didn't see an error code. We unplugged the unit but that didn't seem to do anything.
Posted (edited)
If element new and connections good this is likely your issue and can be returned if not...
Part number: 316557106
Edited by 16345Ed
