My GE Monogram ZDP30L4D2SS door does not close completely. Hinge functions fine and door
is well balanced, but there is a small gap at the top. is there anything I can do to adjust it besides
buying new very expensive door hinges?  $275 cost of hinges
No adjustments on this one. Open the door and make sure it does not open more then 90 degrees. If it does I would replace the hinge receivers with the hinges.
Part number: WB10X5226
Part number: WB10X5225
The odd thing is that the door does not go beyond 90...it makes it to about a 1/4" from closing
Perhaps it's become partially uninstalled. Remove it and reinstall it and see if that helps. Instructions should be in your owners manual.
Just took door off again   lower screws on the hinge receivers were a bit loose  tightened and situation is improved  /acceptable but not quite perfect
I’d also check the door seal. If the door does not shut all the way the door seal can harden and allow heat to escape the oven causing damage to the lock and other components.
