Manufacturer: Kenmore/Frigidaire
Type of Appliance: Wall Oven
Model Number: 790.41003601
This wall oven heats to temperature but then stops heating and the temperature drops. If you then reset the temperature control knob it will heat again but then stops after heating up. I did a search for the manual but was unsuccessful. Other techs have said to replace the potentiometer and the control board and there is apparently a procedure you have to follow to program the new parts which is in the service manual. Thank you
  • marshall450
  • Lighthouse
Noticed that you are new here so I give you a little help. The manual is already in downloads.
11 hours ago, marshall450 said:
Rewatch the video. Kenmore numbers can be a little more tricky to search for. Do not put the dot in the model number while searching. Try leaving some numbers off the end and add a *. Try leaving the first 3 numbers off and add a *. Try something like *4100360*
Edited by Lighthouse
added info
Thank you Lighthouse. After more searching I found the manual.
