marshall450 Posted April 29, 2018 Share Posted April 29, 2018 Manufacturer: Kenmore/Frigidaire Type of Appliance: Wall Oven Model Number: 790.41003601 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): yes This wall oven heats to temperature but then stops heating and the temperature drops. If you then reset the temperature control knob it will heat again but then stops after heating up. I did a search for the manual but was unsuccessful. Other techs have said to replace the potentiometer and the control board and there is apparently a procedure you have to follow to program the new parts which is in the service manual. Thank you Link to comment Share on other sites More sharing options...
Lighthouse Posted April 30, 2018 Share Posted April 30, 2018 (edited) Noticed that you are new here so I give you a little help. The manual is already in downloads. 11 hours ago, marshall450 said: Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): yes Rewatch the video. Kenmore numbers can be a little more tricky to search for. Do not put the dot in the model number while searching. Try leaving some numbers off the end and add a *. Try leaving the first 3 numbers off and add a *. Try something like *4100360* Edited April 30, 2018 by Lighthouse added info Link to comment Share on other sites More sharing options...
marshall450 Posted April 30, 2018 Author Share Posted April 30, 2018 Thank you Lighthouse. After more searching I found the manual. Link to comment Share on other sites More sharing options...
