Dear fellow members,
I would like to get some help from the experts before to pull the trigger and to buy a new timer. My Frigidaire Heavy Duty Washer/Drier Combo has a problem. The washer's timer begins filling the tank with water and starts washing normally, however, when it finishes washing, the next cycle doesn't start. Next cycle is to drain the water but the timer doesn't move forward. I have listened and observed the timer and it is dead at that point. Is this fault linked to the timer or could be another issue ?? Thank you so much for any help.!
  • dvjorge
  • certified tech group 51
  • darren412
You have to post back with the model and serial # of the laundry unit if you need help on this site. There are good techs on this site and a model # is needed for them to properly diagnose your proble
Thank for your answer. Model is FLXE52RBS8 and the Serial# is XE90528376. I have moved the timer manually and the drain and spin don't work, however, the washer does.. Thanks again..
lid switch, find your wire diagram and check  the lid switch assy. switches....P/N134101800...
Edited by certified tech group 51
