Kitchenaid KSRL25FT5500 Side x Side Refrigerator need help
w5jv@hotmail.com
Hello,
As per the title, we have a Kitchenaid KSRL25FT5500 side x side refrigerator/freezer.
Lately the freezer side is very slowly getting warmer.  At first we noticed ice cream in the middle
was not hard.  This AM I see that a small platic tub of ice (my own mold for a large travel mug)
is not completely frozen.   A week ago I found a large patch of ice on the lower part of the rear
wall about 1" thick and the size of a frisbee, maybe 8 inches.  It fell right off when I pried it with
a spatula and the wall has since been okay but the freezer seems to be struggling.
What can I do to get it back to normal?
Thank you
Sounds like defrost system failure.
Three suspects defrost control
defrost thermostat
defrost heater
Might also be clogged evaporator drain line. Gotta take evaporator cover off and see what’s going on.
Is the fan running?  Open door and listen  for it in the freezer when  the unit is funning ( fan at the back running)
Unplug,  Take off the back cover in the freezer and.  Check fan for  ohm reading.  Check for continuity  of the heater and  the bimetal(thermoatat). If they are good you likly have a control bad.
 If non of this make sense call a pro and expect 2-400 or  other depnding on local rates and part Prices etc
