Hi,  I have a LG WT5001C Top Loader Washer that has loss power.
The lid was locked, I got that unlocked thanks to your video, but still had no power.
 I replaced the main board, no power.  I replaced the Noise Filter, still no power.  I tried a different outlet as well as flipped the breaker a couple times, still no power!  I don’t know what else to do.  Feeling frustrated and defeated!  Can anyone help?
You need a meter and check the outlet your plugging into first then follow the path of electricity in the wire harness until you find where it stops and does not continue further like it normally would have. Check all harness connections for the path of electricity coming from the wall outlet to the main control. You may have a bad connection somewhere in the power cord also.  Trace the circuit with a meter till you find it
Verify correct Main Board...
Should be...EBR62198105
Plug a lamp into the outlet that is used for washer...if lamp works...should be okay.
There are 2 plugs on the Display Board...that should be connected to the Main Board...verify that all plugs on both boards are connected.
Has the top cover of the washer been lifted/raised? If yes...inspect the wire loom/harness...at the top/right/rear corner for evidence of damage. Repair as needed.
