I have a model 110 2513 410 Kenmore top load HE washer that doesn’t want to go into the wash cycle. Lid locks load sensor appears to be working but won’t engage in the wash cycle. Any help would be appreciated.
So far I have unplugged and restarted, tried different cycles, water is working fine.
  • Replies 5
  • Jrod18
  • darren412
  • johntech
It needs to be looked at by a technician that knows how to pull up the error codes in the machine. You have to start first by seeing what if any error codes have been recorded by the main control. Then go from there
Appreciate you getting back to me Darren.
Thank.
Thank.
Without any more info on its earliest error codes . The avenues from where to start can be slim for you especially if you do not have any experience with working on these machines ???
Make sure the pulley has not  came loose. Tilt the machine back and remove cover  for inspection. If it has came loose reassemble with locktight, There is normally a tech sheet in a sleeve glued on the inside of the cabinet. You can reach it from the bottom with the machine tilted back. It should be on the front left hand side near the top. That will give you instructions on pulling the error codes.
Thank you. Love the Kung Fu Chicken
