Samsung Fridge RS267TDRS Help 22e code plus more issues....
I have a Samsung Side by Side that is locked up on a 22e code. It has dual cooling in both the freezer and refrigerator. When I power on the refrigerator it immediately reads 22 E code. The lights are on inside, but nothing happens. I've done my homework, but a 22e code seems to be a simple refrigerator fan issue. However, wouldn't the freezer at least work if it was just the refrigerator fan? Again, the refrigerator is locked up and nothing can be done on the screen. Also, there is a clicking in the freezer door ice dispenser. The clicking sound looks like it's coming from the mechanism that turns the ice in the bin.
I called a repairman and he said that both mother boards needed to be replaced at a minimum. He thought it could possibly have even more issues, but since he couldn't even get the refrigerator to do anything, that both motherboards needed to be replaced. Ugh.
Thoughts? Thank you so much in advance
  • Replies 1
  • TexasDude
  • Lighthouse
Probably done in error but there is No need to start 2 threads for same problem.
Maybe you or Admin can delete this one to cut down on confusion
link to other thread:
