Goes directly to agitate regardless of cycle setting.
Fill solenoids, level switch and timer all check for continuity.
Thanks in advance other troubleshoot ideas.
  • Replies 6
  • RcrX
  • evaappliance
  • Lighthouse
  • LearningTech
blow thru the tube that goes from the pressure switch to the tub, if it is clear you have a bad pressure switch .
tubl clear so will order up a pressure switch.
Shipping will take a week. In the interim, can the switch be jumpered?
This switch senses different values at different levels so jumping will not work correctly and cause you further problems.
It could be done , but as lighthouse said it would be very problematic to do so , I would just go to a laundrymat till the part comes.
On 6/2/2018 at 3:45 PM, RcrX said:
switch be jumpered?
Yes but its not practical, or safe if it requires you to ask it here.  Try knocking it lightly with a back of a screw driver to knosck it loose
