jtelepan Posted June 1, 2018 Posted June 1, 2018 (edited) Manufacturer: Miele Type of Appliance: Dishwasher Model Number: G 6885 scvi Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes Good evening fellows, I am requesting this service manual for this Miele dishwasher my client has. No luck finding it. Complaint of what the dishwasher is doing that it shouldn’t be doing is that the door keeps opening and closing. It operates on a knock to open door latch assembly. This is the first encounter I’ve had with a machine of this quality of technology. Most definitely need the documents to properly trouble shoot. Anyone who has experience with these machines I would appreciate your input as well. I also have 2 other Miele appliances I need help finding the service manuals for. A washer and dryer. Washer mode number pw6068- searched service manuals there is manuals for models pw6065,pw6066. Customers complaint is she doesn’t know how to set rpms for spin cycle. Not that she even knows what that is to begin with but would like to solve that as well. When I tried to set it it would not accept the selection from the dial used to select options. Dryer mode number- Pt7138 plus us Dryer fell off of washer from not being mounted correctly. The dial to select cycles intermittently gets stuck and doesn’t not turn as freely as it should. Also clip that held lid on cracked in the back. Should probably obviously change either user interface if not control board depending if they are all one assembly. Service manual is not as much of an emergency for this unit as much as the other two appliances. Thank you, John T Edited June 1, 2018 by jtelepan Added 2 more Miele products that I need help finding documents for.
Team Samurai Samurai Appliance Repair Man Posted June 1, 2018 Team Samurai Posted June 1, 2018 Uses the 6000 series service manual
