Maytag Washer MHWE201YW00 leaking
jjbodean1970
Washer is leaking from the tub, dripping down the concrete (pic link below). I've checked the bellow for any obstruction and found none. Is it likely time for a bellow replacement?
Thank you in advance for your help
https://1drv.ms/u/s!As9x9R-02HG_-SQwW8P84pDvV1Rf
  • Replies 6
  • jjbodean1970
    4
  • Lighthouse
  • Gnominator77
Posted Images
If it leaking from the bellows then yes. Is there a tear or hole?
Watch video on this link
Part number: AP6020669
jjbodean1970
yep, upon close inspection i've found about a 2cm tear, looks like bellow replacement in my future. thanks for the reply and link to the video.
Have you noticed any clothing coming out damaged from the washer? Your model is listed under the Whirlpool service bulletin for possible clothing damage from the glass being curved. They suggest to replace the bellow and the curved glass with a flat glass replacement.
jjbodean1970
i haven't noticed any damaged clothing other than a sock that got eaten by the sock monster and ended up clogging the drain pump.
do you have a link to the flat glass replacement?
jjbodean1970
awesome, thanks for the heads up!
