Dacor Rds30s convection fan removal.
replacing last of the oven burners of which came with a fan that sits in the center of the burner on the back wall of the oven.
problem being is the fan is held on with a nut & no leverage is available to hold the spinning shaft.
how is this normally done?
craig
  • Replies 8
  • Seaswood
    6
  • LearningTech
Not familiar wiht that exact one, but  i unually hold the fan blade
Did that, I was assuming the nut comes off counterclockwise?
i added blaster some heat as holding blade no longer worked.
  Not sure on direction. If yo uhave replacement motor look at the threads.
 Some are CW to come off
If I could find out the thread size, direction tap & die set is missing somewhere?
installing new oven elements last one was the round one around the convection fan the new burner element came with a new fan blade washer & nut.
so I thought it could be removed, I do believe it did unscrew somewhat just not sure how far.
so I am heating nut giving it a little blaster, periods of heating cooling.
the heat hopefully allowing oil to be drawn to threads!
I think maybe the circlip that fell out when I was unthreading the nut was what was holding the fan blade in the proper location.
so maybe if I can fit it back in place? There is not much room there?
  • 2 weeks later...
Bought spare motor fan assembly & threads are backwards or to the right removes nut!
Glas you found out
Well lucky I could buy a spare motor ebay, that has all working parts so I could see how it works.
the clip that is on inside of fan blade was ruined by turning nut wrong way.
spare unit I got had one so that should go back together.
awaiting igniters for top burners.
