Manufacturer: Whirlpool
Type of Appliance: Dryer
Model Number: CGD8990XW0
This is a commercial coin-op unit. Couldn’t figure out how to get the top up and the unit is completely dead. Thanks!
Here you go:
Thanks,  but I had the tech sheet. Do they have a service manual for this model? I couldn’t find one on ServiceMatters. I need to figure out how to disassemble this beast.
This one should be close enough
This one isn’t that style at all. It’s only a couple years old, commercial with a coin box on top. Front controls. Sorry to be a pest but a manual would make this much easier to get into. The top is hinged but it looks the front of the top was screwed down with brackets. Thanks!
Service Matters doesn’t list a Job Aid for this model family but see if the Maytag Centennial Job Aid helps with disassembly
I've gone ahead and uploaded the parts list too -- that can also be helpful in disassembly.
Just an update to help anyone else. I went back with a fresh brain and the console part comes off once you remove all the security torx on the front. Once that is removed you have access to all the brackets for the top. I had removed half of them the first time and it didn’t seem to loosen at all so I stopped. Must have been a tired brain that day.  Sometimes walking away and coming back for a fresh look helps.
