Coin Op Maytag Neptune Coin Op MAH21PDDWW unknown error code
The first digit of the display is flashing between 1 and 2. The last 2 digits display 28. This isn't even the same format as the error codes on the tech sheet. Anyone have a clue? Thanks.
  • Square Deal Appliance
  • 16345Ed
Typically if unit throws undocumented error the board is wacky.
I finally figured it out. In case the information is of value to anyone else, there is a switch in the back of the coin box. If that switch fails, or the box is not in place, it throws the error code I described. It does not seem to be in any of the literature.
