Diagnostics for a GE GSL25IFRFBS SBS Refrigerator
ApplianceLearner
Manufacturer: GE
Model Number: GSL25IFRFBS
I downloaded the mini tech sheet on the site for this but it does not show how to put the unit in diagnostic mode.  This is a strange problem to me. This unit has the following symptoms:
Freezer is warm at the top and  about 28 degrees at the bottom.  The FF section is warm at the top and freezing the food at the bottom. The damper at the top does not open no matter where the temperature adjustments are. I did find that there is an extra port blowing cold air from the freezer to the ff on the bottom of the unit which I have not seen before. At first I thought it might be the damper at the top of the unit which has a stepper motor and a thermistor attached to it, but the evaporator fan is also not running.  However, in the refrigerator course it said that on a bldc fan motor with the micom you have to put it in diagnostic mode to verify that that micom is sending the right stuff to the fan motor.  I can't find anything that tells me how to do that. Since the damper also doesn't seem to be working, I am thinking it is the control board that is bad but I want to prove it.  Any help would be appreciated.
  • Replies 9
  • ApplianceLearner
    6
  • Son of Samurai
ApplianceLearner
I also can't find the thermistor data table for this unit.
Here's the document you need -- it has diagnostic mode instructions and the thermistor data.
As for your description of the problem you're facing, hop on over to the Appliance Repair Tech forum and post it as a new topic there. That's the place to get technical help.
ApplianceLearner
Thank your very much.  That was superfast
ApplianceLearner
sorry, i downloaded the file, but i don't see the information there.  is this the right file? i will post the problem in the other forum.
You're right, I linked the wrong one. My bad! Here's what you need:
ApplianceLearner
This file has the information i'm looking for but not for the model I have.  my model number is gsl25ifrfbs.  This file doesn't list the GSL25* anywhere
ApplianceLearner
my model has manual controls for freezer and ff but it also has a micom and dc evap fan motor and stepper motor controlled damper.
Your model uses the same control board as the units listed in that file, so the diagnostic procedure should be the same.
@ApplianceLearner - Let's move this discussion to your topic in the Appliance Repair Tech forum.
Guest
This topic is now closed to further replies.
