Ice Door Flap - GE Refrigerator # ZFSB25DMD SS
Reaching out to see if anyone can help with the steps to take apart the door panel and expose the Ice Chute Flap to see if it needs replacing, lubricating, etc..  I have an air leak that is causing a build up of ice on the inside of the door even though the flap appears to be closed.  It definitely is sticking open at times where I have to push on it to fully close.  Any diagrams or guidance would be appreciated.
  • Replies 4
  • Zonker
    4
  • 16345Ed
Dispatcher?RequestType=Image&Name=030051
What I'm trying to figure out is how to remove the door bezel pictured above
Thanks for the reply.  Yes I had already seen this video.  The problem is that the bezels are different and I don't see how to remove mine. I'm wanting to be careful not to break it as the part is no longer available.  The parts diagram doesn't really tell me how the bezel is removed just how it pieces together once the bezel is removed.
  • 5 weeks later...
Should have known better to search on Monogram instead of GE.. anyway hope this helps anyone else trying to gain access to the Ice Flap on this model refrigerator...
