WTW5000DW1 - Center spinning only
Adam Carter
I have a Whirlpool VMW, (I'm new to them) in which on spin, only the center agitator spins.  Am I looking at a Splutch?  The shifter actuator appears to be working properly.  Thanks!
  • 3 months later...
  • LearningTech
  • sh2sh2
  • Adam Carter
Could be splutch or a shifter, most often i see the pulley loose or worn on the bottom
Edited by LearningTech
Pulley is part of slutch kit. Use blue loctite
Check the basket hub
