I have a whirlpool duet sport dryer that is not drying. The display panel looks like it is ready to go and then you press start and nothing. I replaced the control panel thinking that was the problem, but no luck.  Any ideas???
Thanks
  • Replies 4
  • Lighthouse
  • noPower
  • 16345Ed
Thanks
oh model number : wed8300sw0
Was the tech sheet still inside the dryer cabinet?
If so did you read this part of it and follow the test?
WON’T START CYCLE WHEN START BUTTON IS PRESSED.
1. If number display flashes, check to be sure the door is completely shut, and press and hold down START for about 1 second.
2. See TEST #2, page 5.
3. See TEST #6, page 9.
Sometimes it really is cheaper to hire a professional.
