Manufacturer: LG
Type of Appliance: Top Load Washer
Model Number: Kdte504d
Requesting service manual only showed the bulletin info for this model.  I have a washer that continuously drains even after i turned the power off.
  • Replies 4
  • candpappliance
  • David C
model number pulls up a kitchenaid dishwasher?
I’m sorry I don’t know why that’s the model I posted the model number is WT4970CW
So as soon as its plugged in it starts to drain and never stops? never runs a cycle? or does it run a cycle and when it gets to drain it never stops? Can you get it into diagnostics mode?
  • 2 weeks later...
When power is turned on the unit starts draining and if i pick a cycle such as rinse an spin the unit will fill with water as if its rinsing.  Checked the flood sensor an its good.
