Manufacturer: Fisher Paykel
Type of Appliance: Washer
Model Number: WA4127G1
Need this manual for a leaking washer
thanks
Edited by fillthebarman
  • Replies 6
  • J5*
  • fillthebarman
  • coolhandluke
You need a manual to find a leak ?
to take the damn thing apart but I did find one in the counsel.  Pain in the but.
First thing
check the inlet hoses they are rubbish
did you tilt it back and check the drain pump ?
To open up
unscrew the 4 screws along the back of the topdeck
the top deck haa hooks on each corner that hook into the top of the suspension
you need to push the hob towards the back to get the rear hooks to unhook from the suspension towers
once you get the rears then push forward to unhook the fronts
it takes a bit of pushing and shoving but gets there
beware snapping the inlet hoses and the earth wire that’s in the middle of the deck at the rear attached to the cabinet
other leaks I have seen are from the fill hose from the valves into the bowl
Here is something close, but a leak? Does it leak during fill, wash or drain?
Edited by Son of Samurai
Cleaned up the post by deleting attachments and replacing with a link to the file in Downloads section.
I could not see where the leak was coming from so I wanted to take off the top to look down but when I got it started again with the top off water was flowing from below washer and it looked like it was coming from tub seal because it was flowing fast over the motor.  i recommended new.  It was a salon that had beat it good for 10 years.
Prob right on the tub seal , although you don’t normally get fast leaks like that
I have see something get stuck under the bowl and wear through the outer tub cause a hole and fast leaks
that machine would have been about 6 years old max as that’s when they brought that model out
either way 6 years is a pretty good life in a salon
I usually see 2-3 years for the condenser dryers , they get hammered up to about 8 loads a day
