New Appliance Service Manual added: Samsung DW80M2020US Dishwasher Service Manual
  • 1 year later...
  • Son of Samurai
  • Mr app of Lex
Looking at a 8/2018 version of this dishwasher. Try to start any wash cycle and the machine just wants to run drain pump. Sump is clear, water supply is good, anyway I added about 10 cups of water to sump and started a wash cycle. It drained and filled with water and began wash cycle. To start another wash cycle I had to add water to sump again. I ran a self test. Normal and Express flashed alternately. I then reset power . I have started and stopped 3 wash cycles successfully. ...why would the drain pump keep running and prevent a wash cycle to fill to start cycle? ? ?
Please post your question as a new topic in the Appliance Repair Tech Forum. That's the correct place for repair questions. You can find the Tech forum by reading through the forum listing on the homepage of Appliantolgy. If you need to reference it in your post, you can link to this manual.
