I have a koce500ess01 microwave/oven combo.
Originally the oven worked fine and the microwave wouldn't work.
The MW would say the door must be opened and closed, then I would also get a code of F6E8, which doesn't seem to be listed for this model.
I replaced the door switch assembly and also found the line fuse was shorted, I replaced the fuse and re-tested.
No more door error but 1 second into starting it pops the line fuse and you can hear it, the display says its "Cooking".
I have tested continuity through the wiring and no shorts or issues, I tested the safety fuses and the magnatron, all good.
What can be shorting the line fuse this way and causing this problem?
Plz help!!
  • Replies 4
  • FoxRepairs
  • myrepairman
  • alldone1
  • Alanwalker
The transformer
Check microswitch at the door first there should be 2-3 on the right and 1-2 on the left. If they pass the continuity test / check wires to ground/ you can check the meg by simply unplugging it and running a the MW see if it still blows a fuse/ check mfd on capacitor/ check pcb and noise filter for visual burn outs. Best of luck.
  • 3 weeks later...
Thanks for the post. I was too having such an issue with my microwave. This post seemed helpful.
  • 3 years later...
Alan, did the issue get resolved ?
