How to find a substitute thermostat for freezer model FCM5DMCWH
I have determined the thermostat is bad in my freezer and having a hard time finding a replacement .  the part number is WR09X10053.   the appliance part stores say it is not longer available and there is no cross reference.     the only one i can find is on ebay for $65 !   more than i think the freezer is worth.
any idea on how I might be able to use a substitute  from a different model?  thanks
If you don’t think it’s worth $65 buy a new one. Geesh.
well i think it cost me $40 bucks and  I have no idea how old it is . .looks very old.  i got it used.  have had it for  over 4 years..used it for ice machine following rotator cuff surgery.  a new one cost over $150.     and i am on a limited income.   so i had to get creative and will look for a new "used" one.  actually found one for free.
and since I bypassed the thermostat.. i am using an appliance timer to run it about 1/2 time.   a repair person told me freezer run about 1/2 to 3/4 of the time.. so i am experimenting with the timer i had on hand in the meantime.   :)   sometimes  i have to get creative.   i haven't yet found a tree that grows money.
and considering i spend 10K a year out of pocket on health care-       a penny saved is a penny earned.    '
I also saw that something like this may work
https://www.amazon.com/gp/product/B074NYSHBM/ref=ox_sc_act_title_1?smid=A1RUFFFCQ74BCW&psc=1
Considering they have discontinued the cold control for your unit and due to many factors they are not going to make a new part for a set of models of this age your find on amazon could work with some experiments to find the best placement of the probe.
if you can't afford to spend $65.00 on a new  cold control as 16345ed  has explained you should be doing .   I would suggest you go on craigslist or something and get a free fridge or freezer if available. Even a free fridge that works  will have a freezer.   The advice he gave you is the only sensible professional answer and the proper one.  Any other answer to your solution would not be in your best interest. contact the seller on ebay also and you can make an offer on the cold control also.      Good Luck !
I always had good luck with universal cold control kits made by Ranco. Not sure if there is a version in America but up here in Canada the VF3 is a popular universal replacement.
https://www.amresupply.com/part/VF3-FREEZER-CONTROL-NO-S
Gnominator77 gave me an idea.. i started searching for a "universal replacement"    then
 i pulled out the thermostat it had this part number on it.   WPF 27A-L  just to see if i could open it up and see if there were any obvious things i could fix inside. .
For now the appliance timer is working  just need to figure out how long to run the freezer and how long to off cycle it ?
when i type in the part number WPF 27A-L    I found one in china
https://www.yoycart.com/Product/553225547370/
and a bunch on ebay .. if i match the specs I wonder will any of them work?
https://www.ebay.com/sch/i.html?_odkw=wpf+27a-L&_osacat=0&_from=R40&_trksid=m570.l1313&_nkw=+freezer+wpf+27a-L&_sacat=0
also working at the free or low cost used solution.  however getting rid of my current freezer might not be as easy as pie.
I will call the Canadian place and see if they know any distrubuters here in the US -
thanks everyone
  • 2 weeks later...
Ok i have the new thermostat  and trying to take the old one out.. it is sealed in with caulking- managed to get the caulking off, but there is a big black "washer/ seal" type thing.. i have tried pulling and pulling on the thermostat probe but can' t get it to come out.   do i need to destroy the black seal that seems to be holding it in  ?  thank you
  • 6 years later...
DarkHorse96
I've also been hunting for a substitute for the GE WR09X10053 part# GE says is the correct replacement for my FCM5DMCWH.  I had little or no luck other than what looked to be discolored, very used-looking parts on eBay.   After seeing QKCAM's post, I bought the Amazon WR50X10085.   But when I attempted to install it, I hit a snag.   The original thermostat on mine was screwed into the back of the temperature adjustment knob's mounting plate with two screws that went through 2 holes into plastic posts on the back of that plate.
My problem is that the Amazon WR50X10085 has no mounting bracket at all.  So the only thing holding a device that's controlling full amperage 120v power would be the friction press-fit of the shaft into the freezer's control knob. That doesn't seem safe to me.
My freezer's original thermostat was labeled "CS6448N" and "WPF27S-103-032").  There was no significant number of visible threads on its shaft.   So I didn't see any obvious way to get the stand-off mount with the screw holes off the original thermostat and onto the WR50X10085.  The 10085's shaft is threaded.   It looked like the tab the knob hits to turn the freezer off prevents the spinner from rotating 360 degrees to unscrew the plate from the original one  (if it is threaded) or to re-screw the old mounting plate onto the 10085.
Just to further confuse the issue, I've since located a supposed "New old stock" WR09X10053 online. for nearly $100.   It's pictures show it does have what looks like a nearly identical mounting plate - but that plate has no screw holes at all.  So apparently the mounting for that thermostat has changed between revisions / serial numbers of this "Compact 5" freezer.
Does anyone have any ideas of how to move the mounting plage from the CS6448N to the WR50X1008?
Thanks in advance.
Wouldn't be hard to make a mount - just use a strip of plumbers strapping cut to the correct length, make "L" bends at each end so enough of the knob shaft will stick through the mounting hole, find a nut the correct size of the center threaded mount.   Drill small enough holes for the two mounting bolts/screws will thread into the plumbers strap or use speed clip nuts if the holes that are in the plumbers strapping is too big and already at the correct mounting screw spacing.
DarkHorse96
Thanks!   That sounds like a viable alternative if I can't figure out how to use the actual mount off the original 10085.   I did notice that there seems to be some kind of bend-over / crimp tag on the bottom 2 corners of both the original thermostat and the substitute.   Has anyone tried to bend those tabs of a dead one to verify whether we could theoretically release both stats' mounts and securely attach the original mount to the 10085?   Of course, I'd also be betting that the 10085's exterior mount will pull off an unseen underlying shaft because that big threaded region its shaft may be too long to fit under the old mount.
@DarkHorse96 Don't try it - you will never get them back together correctly.
After you get the new one mounted by making a mounting bracket like I suggested and you know all is working OK - then try to take the old t-stat apart and see what you end up with.
DarkHorse96
I took your advice and fabricated a mount for the substitute thermostat.   But when I tried to find a nut that matched the threaded part of the shaft on the WR50X1008 to attach that mount, I've been unable to find any nut that will fit that thread.
When i put a micrometer on the OD of the threads, it's slightly less than 3/8".   So I first tried nuts for standard 3/8"nuts starting with standard 3/8" thread, fine-thread 3/8", and extra-fine thread 3/8.  No joy.  The closest metric seems to be M10.   So I also tried nuts for M10 - 1.00, M10 - 1.25, and M1 - 1.50.   None of the above would screw onto that shaft.  (All the nuts I was trying were standard right-hand / clockwise to tighten thread rather than reverse / left-handed thread).
Since I bought that thermostat on the "GE Store" of Amazon, I tried calling GE Customer Support.   But all I got was a circular run-around with no chance to ever talk to anyone that might provide the thread spec.
Does anyone have any idea what kind of nut threading would fit on the threaded part of that shaft?  Imperial / Metric?  Left-hand, right-hand thread?   Some kind of tapered shaft?   Some oddball, in-between-standard sizes thread?  Etc.
Thanks in advance for anyone that can point me in the right direction to get a nut that will fit and allow me to attach my mount?
Pretty sure it a normal R.H. Thread - I do think it maybe metric but don't know the size, (generally nuts that are used in applications such as this are really thin - like around only 1/16" to 1/8" thick).
  • 2 weeks later...
DarkHorse96
It took a good bit of time to identify that thread, but I eventually found it to be an "electrical panel" thread; not a regular M10 "standard, fine, or extra fine" thread.  From what I understand, many appliances need relatively thin nuts to fit into tight spaces and need VERY fine threads to hold securely without requiring a much thicker nut to have room for enough threads for the required holding power.    That's why in my initial testing even standard M10 "extra fine" nuts were too coarse for that thermostat.
Those threads are specified by a adding a specific thread pitch in mm.  Besides their use in electrical panels, appliances, lamps, etc., such thread pitches are also commonly used in panels on cars and trucks.
That particular thermostat's threaded area is an M10 x 0.75mm thread.  (M10 "extra fine" thread is only M10 x 1.0mm).  I bought a small bag of M10 x 0.75, steel, metric hex nuts that are thin (only 2.6mm high) on Amazon.   They screwed right on to the thermostat's threads with no issues.
A 60-count bag was only $7.89.  (There are other offerings for them, but I bought the first one I saw that I could next-day Prime in).   Just bring up Amazon and type the ASIN (Amazon Stock ID Number) "B0CN2JNVXF" into the search box and click the Search symbol.
(Or, if you'd rather search by spec than ASIN, the listing for the bag I bought had the listing title: "PATIKIL M10x0.75 Steel Hex Nuts, 60 Pack Metric Thread Zinc Plated Finished Hardware Nuts Screw Bolt Fasteners for Lamps Machinery Repair 2.6mm Height").
I've been working higher priority projects and haven't yet had time to go back to the chest freezer repair, but this should allow me to mechanically attach a mount to the 10085.
