Have a Summit FFBF 181 that the freezer doesn't get cold enough. Repair tech thought I should replace compressor but that doesn't sound right--any thoughts on what might be going on
You don’t believe technician the physically saw your unit, but you come on line to believe technicians that haven’t seen your unit?
why don’t you trust your tech?
Because the tech that visited didn't perform any diagnostic procedures, and compressor fails my civilian logic test since the fridge is fine. Rather than spend $600 to see if tech is right I want to get a second opinion--which is a pretty common use of internet forums.
So tech looked at the fridge and said yeh nah mate needs a compressor ?
did he actually do anything ?
did he explain the reason why it needs a compressor ?
or is it a guess ?
none of us sitting back here can tell exactly what is going on without more information and testing
Seemed like guessing. Didn't remove the unit, said it was a super common failure on these units, and went on his way. I asked about testing but he wanted  $$ to pull it out to get access.
Afterwards I was super dubious realizing Summit is a rather rare brand so the chances of him having seen this before was slim.
I guess I should just try another tech, but wanted to see if someone here was familiar with the troubleshooting routine for Summits so I could have some independent info.
That unit is a single compressor, single evaporator unit, so troubleshooting a no-cool or weak cooling is pretty universal. It's normal for fridge temps to remain good as long as the freezer doesn't warm beyond the fridge set-point.
If you want to confirm /refute the last tech's diagnosis, listen to the unit over a period of time, get to know the sound of the compressor. It's normal for the compressor to run 10-20 min. at a time, then off for 20-40 min. If your compressor seems to be running more than 50% of the time, the last tech could be right, could be a failing / inefficient compressor, could be a refrigerant leak, or a restriction. All expensive repairs. If the compressor isn't running when the unit should be cooling, your problem is elsewhere.
If you have an infrared temp gun shoot temperature of condenser coils (clean coils first).
Report results.
