removing old thermostat probe on GE chest freezer FCM5DMCWH
I found a thermostat that will work in my freezer..yay!   it was $17 bucks.
Ok i have the new thermostat  and trying to take the old one out.. it is sealed in with caulking- managed to get the caulking off, but there is a big black "washer/ seal" type thing.. i have tried pulling and pulling on the thermostat probe but can' t get it to come out.   do i need to destroy the black seal that seems to be holding it in  ?  thank you
I removed some of the black seal and i can see the white tube that the thermostat probe goes into. I can not get that sucker to come out.  I have been pulling as much as possible and it wont budge, even wiggling the thing back and forth does nothing.     hope someone knows a trick for this .. thanks
You typically need to destroy nothing. Try putting lube on white tube to make it come through , and make sure it is strait
Make sure the far end is not wrapped around anything.
Thank you Learning Tech
 I let the freezer defrost and after that the old probe came right out!   i had no idea it needed to defrost.
I tried attaching the new thermostat to the old probe (before i deforsted the unit) that didnt seem to work.    so i went to reattache the new probe back to the new t stat  and the new tstat fell apart.   using the old one as an example i think i finally got the new one put back together the right way.  time will tell.
thanks for the help!
got the new t stat installed .   I put a couple little water bottles inside to make sure they freeze.   they did freeze but it seems like the motor  is always on  now.  I am wondering if the new (used s stat ) has an issue.  I have 30 days to return it.     I even turned the freezer down to the lowest setting and when i went back to check later the motor was running.
what am i missing here?
thanks!~
Is it zero degrees in the freezer?
either you broke thermostat taking it apart, it was bad initially or you have a sealed system problem.
So you didn't purchase a NEW t-stat.    It was a used one that you purchased?  Not a good item to purchase used, (no idea what kind of condition the points are in or if calibration if off).
I have been running the freezer near the lowest setting and the thermometer reads   a range of -9 to 19F   and the motor is not running continually, like before.   where should the temp be for this?
this thermostat yes was / is used it has a 30day return..  maybe i should just return it.
are the temp ranges in the ball park?  should i try to set the thermostat to a colder temp and see what happens?
thanks
At mid setting it should be about 0 degrees.
thanks  16345Ed  is the temp supposed to fluctuate much at that point?
Only if it’s auto defrost.
no it isn't auto defrost.  I just checked again and am getting about a 14 degree swing.. could this be because i haven't yet sealed up the thermostat tube hole with silicon?
also will it effect the food as long as it stays frozen?  thanks.
What’s the +&- temps you are getting ?
Is it loaded or empty ? As this will affect it
a mechanical thermostat will have a bigger swing in temps and for the deep freeze you are concerned about your average temps
Edited by J5*
thanks 5*   the temps range yesterday was 8 down to -14.  the freezer is empty now except for 2 small water bottles and a container of baking soda.
so it sounds like this is working ok and I can resume use of freezer  with no need to return the $12 used t stat?
