Bintiwangu Posted October 16, 2018 Share Posted October 16, 2018 Manufacturer: Whirlpool Type of Appliance: Washing machine Model Number: WFW9500TC01 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes hello I'm needing a manual / tech sheet on this washer please. Someone posted a link to one here years ago- but it was at "service matters" and would not let me in. It will give an f 21 code sometimes and sometimes says suds. the homeowner has already cleaned debris from the pump on previous occasions and it only works intermittently. How does one know if a similar model is close enough or not as far as tech sheets? I got on a job the other day with a manual that was not exact for a Haier refrigerator, and it had the old school defrost timer instead of a board as the manual showed. Link to comment Share on other sites More sharing options...
Team Samurai Son of Samurai Posted October 17, 2018 Team Samurai Share Posted October 17, 2018 We actually have this one uploaded to the site already -- you can find it by searching with a truncated model number using the "*" wildcard character. Like this: WFW9500T* As for telling what tech sheet is for what model, that can be hard sometimes. Manufacturers will put out a tech sheet that applies to several very different looking model numbers. The best practice is to search our Downloads section using a truncated model number, like I showed. Even better is if you can find the publication number for the tech sheet you need. We include the pub number in the description of every file on the site (when possible), so searching that way is pretty surefire. Link to comment Share on other sites More sharing options...
Bintiwangu Posted October 17, 2018 Author Share Posted October 17, 2018 Thank you Sam I did try the wild card and all I came up with was the one I talked about that I couldn't get into. I will try it again. Link to comment Share on other sites More sharing options...
Team Samurai Son of Samurai Posted October 17, 2018 Team Samurai Share Posted October 17, 2018 Make sure you limit your search to the Files section using the drop down menu from the search bar. That way, the only results that will pull up are downloadable files. Link to comment Share on other sites More sharing options...
