No Volyage To Water Valve
Mr. Mezey
Manufacturer: Kitchenaide
Model Number: ksrb25fkss02
I have an ice maker that's not working because it's not getting any water. I replace the module because the module was burned out to the heater. After putting it through a harvest cycle to make sure everything worked I got no water. It's been through 3 Harvest Cycles now. I checked the water valve by hooking it up direct deposit and it worked fine. It's not getting any voltage during the Harvest cycle.
  • Son of Samurai
  • Mr. Mezey
