Fisher-Paykel DD603 cycling thru display and locked
I haven't seen this before. My FP is beeping at me and the display is cycling through different displays. No error messages.
1. how do I get the dishdrawer to shut down and release the lid so I can open the drawer without damaging it?
2. is the board toast and I should just order a new one, or are there some tests I should do?
  • Replies 6
  • PEvans
    4
  • J5*
The display sounds like it has moisture in it
turn it off at the wall
when you turn it back on at the wall , the first thing it will do is open the lid , so hear that and turn it off again before it closes again and continues the cycle
Thanks very much. I disconnected the power for a minute or two and when it came back on the display looked normal. Also, my wife said she had held the power button down until it turned off and she was able to open the drawer and dry it out, so perhaps some water got where it shouldn't have. Never got an error code though.
It is still misbehaving.
Now when I disconnect the power for a few minutes it comes back on with the normal display, but then flips to a display that says "delay" with the numbers "01" and a flashing lock symbol.
The display is faulty , replace it
is it the display or the control unit?
Display
Edited by J5*
