Hi, this is a GSS25WSTA SS side by side.
Symptoms: no cooling in freezer or fridge, no frost. Front panel is not working, door lights do function.
sounds like compressor or fan may be trying to start, but doesn't (like a PC with a bad power supply, spins up, then off.)
Any help appreciated, where should I start for trying to diagnose this thing?
First we would need to know if the fan by the compressor is turning. If it is and the compressor is trying to start then shutting off then you will most likely need the compressor start relay. If both the fan and compressor are turning off then on then you will most likely need the control. The start relay is a real common failure. .Part number: WR09X10107
