      8
maytag mdb7759awb3 dishwasher blinking steady
After pressing the start button it lights for a few seconds and then blinks steadily.  I did read and note the blinks 7 times note for heater faults and that's not what's going on here.  I did look at the heater element physically.  There is one spot that has a mark on it, but it's not broken.  Sometimes it will start and run.  Other times it will start and run for a bit and then stop.  I've not pulled it out to check the heater element because connections are short and it's a pain.  Is there any other way to determine the control panel is shorted other than to identify the blinking and simply replace it?
  • 2 weeks later...
  • Replies 1
  • bruce.b
  • LearningTech
Could be door switch not letting it start.
 You can look at the pannel you can test through the pannel with a meter.
Look underneath for the tech sheet use into info to RESET the control and tray to see what you get then.
