Kitchenaide dishwasher fills clicks does not run
Kitchenaide dishwasher,  fills with water, then 'clicks' several times. does not go into wash cycle. motor does not start
The unit does drain when cancelling the cycle. Also , starting the diag cycle the unit goes through all the cycles but does
not wash (fills, drains,drys).  I replaced the diverter motor and motor pump
  • tcolati
  • stewartservice
  • Diesel Appliantologist
Possible bad electronic control. Do you have the model and serial # from the unit?
model kdfe204ess1 s/n f54105035
there seems to be power going to the motor
the diag code is 6-4 which indicates float switch. I replaced that also
  • 2 years later...
Did you ever figure it out ? Had same issue once upon a time.
