LG wm3050cw, no longer plays sounds
So obviously this isn't a critical issue. Our washer that we've had for almost 4 years all of a sudden doesn't make sound when you power it on or press buttons. It also no longer plays the cycle end sound, which is probably the most annoying.
I've done a fair amount of searching on this and as I understand it, this model, wm3050cw, doesn't have a way to disable the sounds like some of the newer models do. So what could be wrong? I'm assuming a bad circuit board or something like that? I haven't dug into the machine yet to see if it could be a loose wire or anything yet.
Anyone have any ideas or suggestions?
Chris
  • norsedakotan
  • john63
Press and hold the Water Plus button for at least 3 seconds.
  • Thanks 1
Oh jeez. I had to get right up and look close with my bifocals to realize that it says signal on/off under that button. :blush:
Now I feel silly! Thanks for the quick fix.
Now to figure out who managed to turn it off. I'm going to blame the teenager! ?
Thanks again.
Chris
