      6
Bearing for Bosch WFVC5400UC/19 washer
Does anyone know the part number for the  drum bearings for my Bosch WFVC5400UC/19?  In speaking to Bosch they are only sold as part of the tub/drum assembly for ~$500.
  • Replies 1
  • ruffpie
  • LearningTech
There is no part number as it is not available https://www.ebay.com/itm/Bosch-Vision-Washing-Machine-Drum-Seal-Bearing-Kit-WFVC544AUC-19-WFVC544AUC-20/253200835969?hash=item3af3f22581:g:km8AAOSwUaNZ3GUN
says it comparable for any vision series bosch ( yours is vision)
keep in mind that you will need to carefully remove and then press ( carefully and strait into your tub) anything crooked, or tweaked ever so slightly will make it fail again quick, or never sound right.
 ANY pitting damage to the inner drum support will require a new inner drum.
GET IT APART AND look at any damage, and make sure you can press bearings strait.  before you bother ordering anything you cant return. As if you cant get it apart you  cant get it together and people often grant get it apart ( not without breaking something.  anyway)
I dont even quote things like this untill i have been paid for disassembly, cause you dont even know it its possible to do the job untill you can remove inner tub and  clean up to see damage.
YOU will also need a new tub seal to put between the 2  halves of outer tub when reassembleing.
this is a few hundred in parts ( oem and the not available aftermarket), specialty tools, and lots of labor and lots of room for error.
